史上最全焊接专业英语词汇
查看: 8006|回复: 0
发表于 2015-2-3 12:45:13 | 显示全部楼层 |阅读模式
保护气体shielding gas
变形 deformation
波浪变形buckling distortion
补焊repair welding
残余应力residual-stress
层状撕裂 Lamellar Tear
插销试验Implant Test
常规力学性能convention mechanics performance
超声波探伤 ultrasonic inspection
衬垫焊welding with backing
船形焊fillet welding in the flat position
磁粉探伤 magnetic particle inspection
粗滴过渡 globular transfer
脆性断裂 brittlement fracture
淬火 vt. quench n. ~ing
错边变形 dislocating distortion
搭接 lap welding
打底焊backing welding
单道焊single-pass welding
单面焊welding by one side
导电嘴wire guide ;contact tube
等离子弧焊plasma welding
低合金钢 low alloy steel
点焊 spot welding
电弧动特性 dynamic characteristic
电弧焊 electric arc welding
电弧静特性 static characteristic
电极electrode
电流current
电压voltage
电源power supply;power source
电阻焊 resistance welding
调修correct
定位焊 tack welding
短路过渡 short circuiting transfer
段焊tack
断续焊intermittent welding
堆焊surfacing;build up welding
对接butt welding
钝边 root face
多层焊multi-layer welding
多道焊multi-pass welding
二氧化碳气体保护焊 carbon-dioxide arc welding
反接reversed polarity;positive electrode
返修焊rewelding
飞溅splash
飞溅spatter
分段多层焊 block sequence welding
分段退焊 backstep sequence
封底焊back welding;sealing welding
缝焊seam welding
根部间隙 root gap;root opening
固体夹杂solid inclusions
过热区overheated zone
焊道bead
焊缝seam welding
焊缝凹度concavity
焊缝成形系数 form factor(of the weld )
焊缝代号welding symbols
焊缝厚度 weld throat thickness
焊缝金属weld metal
焊缝宽度weld width
焊缝凸度 convexity
焊根root of weld
焊后热处理 postweld heat treatment
焊机welding machine
焊剂fluxes
焊脚尺寸 fillet weld size;size of a fillet weld
焊接变位机welding positioner
焊接变位机positioner
焊接材料 welding material
焊接残余变形 welding residual deformation
焊接翻转机welding tilter
焊接工艺welding technology
焊接工艺参数 welding condition(welding parameter)
焊接工艺评定evaluation about technology of welding
焊接工作台 welding bench
焊接规范welding norm ;welding specifation
焊接机器人 welding robot
焊接技术 welding technique
焊接夹具 fixture
焊接缺陷 crack imcomplete penatration
焊接热循环 weld thermal cycle
焊接熔池 welding pool
焊接顺序welding sequence
焊接速度 welding speed
焊接位置 position of welding
焊接温度场 welding temperature field
焊接性weldability
焊接性weldability
焊接应力 welding stress
焊瘤overlap
焊枪welding gun
焊丝 welding wire
焊条 welding rod;electrode
焊趾 toe of weld
横焊horizontal position welding
横向收缩变形transverse shringkage distortion
后热postheat
弧长length of arc
弧坑裂纹 crater crack
划线criibing
混合比mixing ratio
基本尺寸 basic dimensions
激光焊laser beam welding
夹紧力clamping force
间隙 gap
减压器pressure regulator
交流 alternating current
角变形angular distortion
角接 fillet welding
接头 joint
近缝区Near Weld Zone
开焊接坡口bevelling
快速割嘴 nozzle for high-flame cutting
扩散焊diffusion welding
冷裂纹Cold Cracking
立焊vertical position welding
连续焊continuous welding
流量 the rate of flow
流量计flowmetre
螺旋变形twisting distortion
埋弧焊 submerged arc welding
脉冲氩弧焊 plused argon arc welding
密封性检验 leak test
摩擦焊 friction welding
母材basic material
内应力 internal stress
耐压检验 pressure test
挠曲变形bending distortion
扭曲变形 distormation
喷射过渡 spray transfer
喷嘴nozzle
疲劳性能 fatigue property
平焊flat position welding
坡口 groove
坡口角度groove angle
气孔gas cavity
气密性检验 air tight test
气体保护电弧焊 gas shielding arc welding
钎焊brazing;soldering
切割 cut
氢致裂纹 Hgdrogen induced Crack
清根back chipping
缺陷imperfection
缺陷分级 classification for imperfection
热烈纹heat crack
热烈纹 Hot Cracking
热应力thermal stress
热影响区 Heat Affected Zone
A
actual weld-throat thick-ness焊缝厚度
all-around weld (整周焊缝)环焊缝
angle butt weld斜对接焊
angle weld角焊
appearance of weld焊缝成形
arc-seam weld电弧缝焊
arc-spot weld电弧点焊
arc-weld电弧焊
arc welding 弧焊
aspect ratio of weld焊缝成形系数
at weld edge在焊缝边上
attachment weld连接焊缝
automatic spot weld自动点焊法
automatic weld自动焊接
axis of a weld焊缝中心线; 焊接轴线
axis of weld焊缝轴线; 焊接轴线
arc seam weld电弧缝焊缝
arc spot weld 电弧焊点
arc strike 碰弧
as–brazed 钎接态
as–welded 焊态
argon (shielded) arc welding氩弧焊接
argon tungsten-arc welding钨极氩弧焊
argon-arc welding氩弧焊
argonaut welding自动氩弧焊
atomic H welding氢原子焊
atomic hydrogen welding原子氢焊
atomic-hydrogen welding原子氢焊接
austenite welding不锈钢焊接
autogenous pressure welding自动压合热焊
autogenous welding气焊
automatic arc welding head自动电弧焊接机头
automatic arc welding machine自动电焊机; 自动弧焊机
automatic drying line for welding electrode电焊条自动烘焙线
automatic slag pool welding自动电渣焊
automatic spot welding自动点焊
automatic submerged arc welding自动埋弧焊
automatic submerged slag welding of rail钢轨自动埋弧电弧焊
automatic submerged-arc welding machine埋弧自动焊机
automatic transverse welding横向自动焊
automatic welding自动焊; 自动焊接
automatic welding head自动焊头
automatic welding machine自动焊接机
automatic welding of circumferential seams环缝自动焊
automatic welding process自动焊接工艺规程
automation of welding焊接自动化
arc-welded pipe弧焊管
arc-welded steel pipe电弧焊接钢管
around openings for welded attachments环绕焊接附件孔口
as welded焊态(金属加工微信提供)
as-welded焊后状态
automatic arc welded tube自动电弧焊缝管
air-acetylene welding空气-乙炔焊接
argon arc welding 氩弧焊
automatic slag-pool welding 自动电渣焊
aircomatic welding 自动调弧氩弧焊, 惰性气体保护金属极弧焊
aluminothermic welding 铸焊, 铝热剂焊接
austenite welding 不锈钢(焊条)焊接
automatic submerged arc welding 自动埋弧焊
argon shielded arc welding 氩护电弧焊
all-welded全焊接
all-welded construction全焊结构
automatic spot weld 自动点焊法
AC & D. C. arc welding machine交直流弧焊机
AC arc welding交流电弧焊
AC gas metal-arc welding process交流熔化极气保护焊
AC gas tungsten arc welding交流钨极气保护焊
AC welding set交流焊机; 交流焊接变压器
AC-dc welding machine交直流两用焊机
acetylene welding气焊; 乙炔焊; 乙炔焊接
acetylene welding torch乙炔焊炬; 乙炔接焊吹管
all-position welding全位置焊接
alloy steel gas welding rod合金钢气焊条
alternating current arc welding交流电弧焊
alternating current welding machine交流电焊机
aluminium alloy arc welding electrode铝合金焊条
aluminothermic welding铝热焊; 铸焊
angle backwards welding后倾焊
axial bend test纵弯试验
angle butt welding斜口对接焊
angle forwards welding前倾焊
annealing welding wave退火焊波
antogenous welding氧炔焊
apparatus for butt welding平接压焊夹具
arc braze welding电弧钎焊
arc flash welding电弧闪光焊
arc spot welding电铆焊
arc stud welding柱钉电弧焊; 螺柱电弧焊
arc voltage feedback controlling arc welding弧压反馈电弧焊
arc welding电弧焊; 电弧焊接; 弧焊
arc welding electrode电弧焊条(金属加工微信提供)
arc welding generator电弧焊接用发电机; 弧焊发电机
arc welding generator with independent excitation自激弧焊发电机; 他激电焊发电机
arc welding generator with self-excitation自激电焊发电机
arc welding machine弧焊机; 电焊机; 电弧焊机
arc welding mask电弧焊遮罩
arc welding process电弧焊接工艺过程
arc welding rectifier弧焊整流器
arc welding robot弧焊机器人
arc welding set电弧焊机组
arc welding transformer弧焊变压器
arc-welding electrode电弧焊用焊条
arc-welding plant电焊厂
arcogen welding电弧氧乙炔焊
aircomatic welding自动调弧氩弧焊, 惰性气体保护金属极弧焊
aluminothermic welding铸焊, 铝热剂焊接
argon arc welding氩弧焊(金属加工微信提供)
argon shielded arc welding氩护电弧焊
austenite welding不锈钢(焊条)焊接
automatic slag-pool welding自动电渣焊
B
back of weld焊缝背面
back gouging 背面清根
backing 衬垫
backing gas 背面保护气
base metal 母材
backing groove of weld焊缝反面坡口
backing weld底焊; 底焊焊缝
bare metal arc weld裸焊条电弧焊
bead weld珠焊; 堆焊
bead-on-plate weld堆焊焊缝
beading weld凸焊
beam-to-beam weld梁间焊接; 梁式引线焊接
block sequence weld分段多层焊
bond weld钢轨接头焊接
bridge seam weld桥缝焊接; 桥线焊
brize weld硬焊
braze 钎接接头
brazer 钎接工
brazing 钎接
butt weld对接焊缝
butt weld ends对头焊接端
butt-weld碰焊; 平式焊接; 对头焊接
butt-weld in the downhand position对接平焊
butt-weld joint对头焊接
butt-weld pipe mill对焊管轧机
button spot weld按电钮点焊
back hand welding后退焊; 反手焊接
back step welding反手焊接
back ward welding反手焊接
back welding底焊; 退焊法
back-step welding分段退焊法
backhand welding逆向焊; 右焊法; 后焊法; 向后焊
backing welding打底焊
backstep welding分段逆焊; 分段退焊; 反向焊; 逐步退焊法; 逆向焊
backstep welding sequence分段退焊次序
backward welding后倾焊; 后退焊; 向右焊
balanced welding对称焊
bare welding rod光焊条
bare wire arc welding光焊丝电弧焊
bead welding窄焊道焊接
bench arc welding machine台式弧焊机
bevel welding斜角焊
blacksmith welding锻工焊接; 锻焊
block sequence welding分段多层焊; 分段连续焊接
block welding块焊接
big diameter welded tube大口径焊缝管
blacksmith welded joint煅接接头
butt welded (bw)对焊机
butt welded seam对焊缝
butt-welded drill对头焊接钻头
butt-welded joint对焊接头
butt-welded pipe对缝焊接管
butt-welded rail ends对焊轨端
butt-welded tube对缝焊管; 对焊钢管; 对口焊接钢管
butt-welded with square ends方头对焊
braze welding硬焊, 铜焊, 钎焊
butt welding对接焊, 对焊
butt weld对接焊缝
blasting welding factory爆破焊接厂
braze welding 硬焊, 铜焊, 钎焊
butt welding 对接焊, 对焊
butt weld 对接焊缝
backing run; backing weld打底焊道
block welding sequence分段多层焊
body welding machine罐身焊接机
both sides welding双面焊接
brass welding rod黄铜焊条
braze welding钎焊; 钎焊接; 钎接; 铜焊
braze-welding钎接焊
bridge spot welding带接合板点焊; 单面衬垫点焊; 单面搭板点焊
bridge welding桥接焊; 盖板焊
brize welding硬焊
build (built) up welding堆焊
build-up welding堆焊
building-up by welding堆焊
butt resistance welding电阻对焊; 对接电阻焊
butt seam welding对接滚焊
butt seam welding machine对接缝焊机
butt welding对接焊; 平对焊
butt welding machine对接焊机
butt welding process对接焊法
butt-welding对接焊
butt-welding machine对焊机
C
cap weld最后焊层; 盖面焊缝
carbon content of weld materials焊接材料的碳含量
cast-weld construction铸焊结构
caulk weld填缝焊
contour weld 特形焊接
concave fillet weld 凹角焊
carbon arc weld 碳极弧焊
capability of welding vertically upwards直上焊接能力
capacitor-discharge welding电容放电焊接
carbon arc welding碳弧焊; 碳极弧焊
carbon in materials for welding焊接用材料中的碳
carbon-dioxide arc welding二氧化碳保护焊
carriage of automatic welding machine自动焊机走架
cascade welding阶梯式焊; 山形多层焊
cascade welding sequence串级叠置法
cast welding铸焊
concave fillet weld凹形角焊缝
carbon arc weld碳极弧焊
concave fillet weld凹角焊
contour weld特形焊接
cement-welding金属陶瓷焊接
centralized installation of welding machine多站焊接
chain intermittent fillet welding并列断续角焊缝; 链式断续角焊
chemical welding化学焊
circular seam welding环缝对接焊
circular seam-welding machine环形滚焊机
cleaning before welding焊接前的清理
cleaning of welding deposits焊接沉积的清理
closed butt gas pressure welding闭式加压气焊
cold welding冷焊; 冷压焊
cold-pressure welding冷压焊
combined cutting and welding torch焊割两用炬
combined cutting and-welding blow-pipe焊割两用炬
combined thermit welding加压铸焊
complete penetraction and fusion in welding全焊透
complete fusion 完全熔合
caulking weld密实焊缝
chain intermittent fillet weld链式分段角焊; 并列间断角焊缝
chain intermittent weld并列焊接
circular weld环形焊缝
circumferential weld环缝; 环焊缝
cleft weld裂口焊
closed weld底边无缝焊; 无间隙焊缝
closed-chamber fusion weld闭室熔焊
cluster weld丛聚焊缝
coil weld 卷板对接焊; 卷板对接焊; 板卷焊
cold weld 冷压接
commutator-controlled weld 换向控制焊接
complete penetration butt weld 贯穿对焊
composite weld 紧密焊缝; 强度密封焊缝
concave filled weld 凹形角焊缝
concave filler weld 凹角焊
concave fillet weld 凹面填角焊
concave weld 凹焊缝; 凹面焊; 凹形焊缝; 轻型焊
connective weld 联系焊缝
continuous butt-weld mill 连续式炉焊管机组
continuous fillet weld连续(填)角焊缝; 连续角焊缝; 连续贴角焊
continuous weld 连续焊缝
continuous weld process连续式炉焊管法
contour weld 特形焊接
convex fillet weld 凸角焊缝; 凸形角焊缝
convex weld 凸焊缝; 凸形焊缝
copper weld wire 包铜钢丝
corner flange weld 单卷边角焊缝
corner weld 角焊
corner-flange weld 卷边角焊缝; 卷边角焊缝
crack of weld 焊部裂纹
cross weld十字交叉焊缝; 横向焊缝
cross-wire weld十字焊
crotch weld 楔接锻接; 楔接焊接
cup weld 带盖板焊缝
condenser (discharge) spot-welding machine 电容器放电点焊机
condenser discharge spot welding 电容储能点焊; 电容贮能点焊
constant current welding machine 恒流电焊机
constant energy welding machine 恒功率电焊机
constant voltage welding machine 恒压电焊机
constant-current arc welding power source 垂降特性弧焊电源
constant-current welding source 恒流式焊接电源
constant-power welding source 恒功率式焊接电源
constant-pressure pressure welding 恒压压力焊
constant-temperature pressure welding恒温压力焊
constant-voltage welding machine恒电压焊机
constant-voltage welding source恒压式焊接电源; 平特性焊接电源
consumable electrode welding 熔化极电弧焊
consumable guide electroslag welding自耗定向电渣焊
contact welding 接触焊
continuous feed welding 连续送丝电弧焊
continuous welding 连续焊; 连续焊接
contour welding 绕焊
controlled arc welding 可控电弧焊接
controlled atmosohere arc welding 充气室电弧焊
controlled atmospere arc welding 充气式电弧焊
controlled tungsten-arc welding 自动控制弧长的钨极电弧焊
controlled-transfer welding 可控过渡电弧焊
convex fillet welding 凸面角焊缝
copper arc welding electrode 铜焊条
copper welding rod 铜焊条
copper-alloy arc welding electrode 铜合金焊条
copper-aluminium welding rod 铜铝焊条
copper-nickel welding rod 铜镍焊条
copper-silicon welding rod 铜硅焊条
copper-tin welding rod 铜锡焊条
copper-zinc welding rod 铜锌焊条
core welding-wire 焊芯
core wire for welding rod 焊条芯线
corrosion due to welding 焊接腐蚀
cosmetic welding 盖面焊
cover chain welding 链节式药皮包丝焊接
CO2 arc welding machine 二氧化碳弧焊机
cracking test for automatic welding 自动焊抗裂试验
crankshaft flashbutt welding 曲轴电阻弧花压焊
cross welding 横向焊缝
cyc-arc welding 圆环电弧焊
cast welded rail joint 铸焊钢轨接头
continuous welded rail 连续焊接钢轨
carbon arc welding 碳弧焊
carbon dioxide gas arc welding二氧化碳气体保护焊
D
depth of weld焊接深度
dissimilar weld metal不同的焊接金属; 不同金属的焊接
distance between the toes of a weld焊缝宽度
double groove weld双面坡口焊缝
double-bevel groove weld双斜边坡口焊缝; 双斜坡口焊
double-flanged butt weld双弯边对接焊缝
double-V groove weld双斜边坡口焊缝; 双斜坡口焊
downhand weld平焊缝
duplex spot weld双点点焊接头
deck welding重力焊
double fillet welded T-joint双面丁字形焊接
double-welded butt joint双面焊对接接头
double-welded lap joint双面焊搭接接头
deep fillet welding深熔角焊
downhand welding俯焊
downward welding平焊, 俯焊
downhand weld 平焊缝
double-bevel groove weld 双斜边坡口焊缝, K形坡口焊缝
deep fillet welding深角焊
deep penetration welding深熔焊
deep penetration welding electrode深熔焊条
deep welding深焊
die welding模焊; 冲模堆焊
diesel engine driven DC arc welding machine柴油机驱动直流弧焊机
differential-excited welding generator差激电焊发电机
diffusion welding扩散焊接
direct spot welding双面点焊
direct welding双面点焊
direction of welding焊接方位; 焊接方向
discontinuous welding断续焊
dot welding点焊
double carbon-arc welding间接碳弧焊
double side welding双面焊接
down-hand welding俯焊
downhand welding平焊
downward welding in the inclined position下坡焊
downward welding in the vertical position向下立焊
dual-arc welding双弧焊
double-bevel groove weld双斜边坡口焊缝, K形坡口焊缝
downhand weld平焊缝
E
edge joint weld边缘焊
edge weld端接焊; 端接焊缝; 端面焊缝; 对边焊
electric resistance weld mill电阻焊管机
electric weld-pipe mill电焊管机
groove weld坡口焊; 坡口焊缝; 有坡口焊缝; 凹槽焊
electric-weld pipe mill电焊管机
emporary weld临时点定焊缝
excess weld metal焊缝补强金属; 补强; 补强焊料; 补强金属
excess weld metal(焊缝的)余高
explosive weld爆炸焊接
electric welded anchor cable电焊锚链
electric welded steel pipe电焊钢管
electric-resistance-welded steel pipe电阻焊钢管
electric-welded pipe电焊管
electrically welded tube电焊管
expanded and welded tube joint胀焊
electric butt welding welding电阻接触焊
electrogas welding气电焊
electrogas flux-cored welding气电管状焊条焊接
electro-beam welding电子束焊接
electrode [electrical arc] welding电弧焊
electron-bombardment welding真空电子束焊
electronic arc welding直流电弧焊
electrons leaves welding电子束焊接
electropercussive welding电冲击焊, 电接触焊, 电点焊
electroslag welding电渣焊
electrostatic percussion welding静电焊接
eutectic welding低温焊
exothermic welding铝热焊
edge seam welding端面接头滚焊
edge welding边缘焊接
edgewise welding沿边焊接
electric and pressure welding电压力焊接
electric arc spot welding电弧点焊
electric arc welding generators电弧焊接发电机
electric arc welding machine电弧焊机
electric butt welding电阻接触焊
electric resistance welding电阻焊接; 热电阻焊
electric slag welding电渣焊
electric spot welding电点焊
electric welding电焊
electric welding cast copper solder铸铜电焊条
electric welding equipment电焊设备
electric welding generator电焊发电机
electric welding hammer电焊锤
electric welding machine电焊机
electric welding plant电焊厂
electric welding pliers电焊钳
electric welding rod电焊条
electric welding strip电焊片
electric-arc welding电弧焊
electric-resistance seam-welding电阻缝焊
explosive welding爆炸焊接
edge weld端接焊缝
explosive weld 爆炸焊接
explosive weld爆炸焊接
F
face of weld焊缝表面; 焊接面
fibrous weld纤维状焊缝
field weld现场焊接
filler weld填角焊缝
fillet weld角焊缝; 填角焊; 贴角焊
fillet weld in normal shear (搭接接头的)正面角焊缝
fillet weld in parallel shear侧面角焊缝; 侧面填角焊
fillet weld in the flat position角接平焊; 水平角焊缝
fillet weld in the horizontal position横向角焊缝
fillet weld size焊角尺寸; 填角焊缝尺寸
flame weld火焰焊接
flange weld卷边焊缝; 卷边焊缝
flange-to-web weld卷边焊缝; 卷边焊缝
flanged butt weld弯边对接焊
flanged edge weld卷边焊; 卷边焊
flash butt weld闪光焊
flash weld闪速对焊
flat faced fillet weld平顶角焊缝焊接
flat fillet weld平角焊
ing of fillet weld角焊缝平焊; 船形角焊
flush fillet weld平角焊
flush weld削平补强的焊缝; 平焊接; 无加强高的焊缝
forge weld锻焊焊缝
forged weld (焊后锻压的)锻压焊缝
form factor of the weld焊缝成形系数
formation of weld焊缝成形
front fillet weld正侧面填角焊缝; 正面填角焊
front(al) fillet weld正面角焊缝
full fillet weld满角焊缝; 全角焊
full penetration butt weld满对接焊
full weld满焊
full-fillet weld满角焊
full-sized weld全尺寸焊缝
full-strength weld (与母材等强)等强焊缝
fillet welding (填角焊)贴角焊
fillet welding in the downhand position船形角焊
fillet welding in the flat position船形焊
fillet welding in the horizontal position横角焊
fillet welding in the vertical position立角焊
fine welding精密焊接
fine wire welding细丝焊
fire cracker welding躺焊
fire welding锻焊; 锻接
fixed welding machine固定式焊机
fixed-position welding定位焊接
flame welding熔气焊
flare welding喇叭形坡口焊接
flash butt welding闪光对焊; 闪光对接焊
flash welding闪光电弧焊; 闪光焊; 闪焊; 火花电弧焊; 火花对焊
flash-butt welding电阻闪光焊接
flashover welding闪光焊
flat position welding平焊; 顶面平卧焊
flat position welding of fillet weld角焊缝平焊; 船形角焊
flat welding平卧焊(金属加工微信提供)
flexible welding rod软焊条
flexible wire for electric welding电焊软线
flow welding流注焊接; 浇焊
fluid welding流焊
flux-cored welding包芯焊条焊接
fly-wheel type friction welding贮能摩擦焊; 储能摩擦焊
flywheel friction welding惯性摩擦焊
forehand welding向前焊; 向左焊; 左焊法; 左向焊; 正手焊
forge welding锻焊; 锻接焊
forward welding正手焊; 左焊法; 左向焊; 前进焊; 前倾焊; 向前焊
friction welding摩擦焊; 摩擦焊接
friction welding machine摩擦焊接机
frontal fillet welding正面角焊
full automatic welding全自动焊
full-automatic arc welding全自动电弧焊
full-fillet welding满角焊
full-fusion thermit welding热剂铸焊
full-fusion welding全熔合焊
full-length welding满焊
fusion pressure welding熔化压接
fusion thermit welding热剂熔焊; 熔化铝热焊
fusion type plasma arc welding熔透型等离子弧焊
fusion type welding熔透型焊接法
fusion welding熔焊接
fillet welded joint填角焊缝
forge-welded (monolayered) cylinder锻焊式单层圆筒
forged and welded vessel锻焊式容器
fine welding精密焊接
fine wire welding细丝焊接
flash butt welding闪光对接焊
flat position welding(顶面)平卧焊
flat position of welding平焊位置
forehand welding顺手焊接
foreward welding左焊法
fusion welding熔焊
fusion thermit welding熔化铅热焊
furnace butt-welded pipe对接炉焊管
flywheel type friction welding; inertia welding储能摩擦焊
fusion welding metal熔焊金属
fabrication weldability工艺焊接性
G
gap weld特殊点焊; 双极单点焊
gas-pressure weld气压焊
girth weld环形焊缝
gravity weld倚焊
groove-weld joint有坡口焊接接头
galvanized and welded steel pipe镀锌焊缝钢管
galvanized electric welded mesh镀锌电焊网
galvanized welded tube镀锌焊缝管
galvanized welded wire mesh镀锌电焊网
gas welded joint气焊接头
guided-bend test for butt welded joint对接接头靠模弯曲试验
gas-electric welding气电联合焊接
gas metal arc welding气体保护金属极电弧焊, 熔化极气体保护焊
gas shielded arc welding气体保护焊, 气体保护弧焊
gas shielded magnetic flux arc welding磁性焊剂气体保护焊
gas torch welding炬焊
gas tungsten arc welding钨电极惰性气体保护焊
girth welding环缝焊接
gravity welding重力焊, 重力式电弧焊
gas carbon-arc welding气保护碳弧焊
gas electric welding气电联合焊接
gas metal-arc welding气保护金属极电弧焊
gas shield welding气体保护弧焊
gas shielded arc welding气体保护电弧焊; 气体保护焊
gas shielded arc welding machine气保护弧焊机
gas shielded arc-welding machine气体保护弧焊机
gas shielded magnetic flux arc welding磁性焊剂气体保护电弧焊
gas shielded metal-arc welding气体保护金属弧焊
gas shielded welding气体保护焊
gas torch welding气炬焊
gas tungsten arc welding气体保护钨极电弧焊
gas tungsten-arc welding气保护钨极电弧焊
gas tungstun arc welding钨极气体保护焊
gas welding气焊; 乙炔焊
gas welding device气焊设备
gas welding equipment气焊设备
gas welding machine气焊机
gas welding outfit气焊机
gas welding rod气焊焊丝
gas welding rubber hose气焊橡胶管
gas welding technique气焊工艺
gas welding torch butt气焊进气硬管
gas welding tube mill瓦斯焊接机
gas welding work气焊工作
gas-arc welding气电焊; 气体保护电弧焊
gas-arc welding gun气电焊焊嘴
gas-press welding气压焊
gas-pressure welding machine气压焊接机
gas-shielded stud welding气保护柱钉焊接
girth welding环缝横向焊接
gravity type arc welding重力焊
gravity type welding倚焊
gravity welding重力焊; 重力式电弧焊
groove welding槽焊; 坡口焊; 开槽焊
guided automatic welding导向自动焊接
gun welding machine手提式点焊机; 点焊枪
gas-pressure weld 气压焊
groove weld 坡口焊
groove weld坡口焊
H
hammer weld锻焊
hand weld手焊焊缝
height of reinforcement of weld加强焊缝高度
helical-weld pipe螺旋焊管
high performance weld flux高性能焊剂
horizontal fillet weld横向角缝焊接
horizontal weld横向焊缝
horizontal-vertical fillet weld横向垂直角焊缝
hot weld encapsulation热焊封袋
hydraulic automatic weld液压自动焊接
hydraulic weld process液压焊接法
horizontal bend test横弯试验
handhole with butt welded flange对焊法兰手孔
helically welded tube螺旋焊接管
helically-welded case螺旋焊接壳体
high frequency welded spiral fin tube高频焊接
high strength welded pipe高强度焊接管
high strength welded steelpipe高强度焊接钢管
high-frequency electric welded steel pipe高频电焊钢管
high-frequency straight seam welded pipe高频直缝焊接钢管
holes in joints of welded vessels焊接容器接头处的孔
hammer welding锻接(金属加工微信提供)
hard facing arc welding表面加硬电弧焊
heated-tool welding热烙铁焊接
helium shielded welding氦气保护焊接
hidden arc welding潜弧焊, 埋弧焊
high-frequency induction welding高频感应焊接
horizontal fillet welding水平角焊接
horizontal-rolled-position welding滚动水平焊, 水平转动焊接
hydrogen atomic welding原子氢焊接
high strength weldable aluminium alloy高强度可焊铝合金属
hafnium welding wire铪焊丝
hammer welding锻焊; 锻接; 锤焊
hammered resistance welding锤锻电阻焊; 电阻加热锻焊
hand welding holdet手焊焊把
hard-welding硬质合金熔焊
hammer welded pipe锻焊管
heliarc weld氦弧焊
horizontal position of welding横焊位置
(未完待续)
